[Qgis-developer] problem with GROUP BY in `Execute SQL` Processing
RĂ©gis Haubourg
regis.haubourg at eau-adour-garonne.fr
Fri Jan 16 02:12:29 PST 2015
Ok,
I see some issues:;:
1- your query does WHERE + GROUp BY. SQL standards requires a HAVING
CLAUSE with group by:
select * from au group by ID HAVING ID > 100
2- Geoprocessing waits for a spatial layer in return. I think you need to
add explicit aggregate operators for your columns and geometry columns.
select ST_UNION(GEOMETRY) GEOMETRY, sum(myfield1) sum FROM au group by ID
HAVING ID > 100
3- not sure geoprocessing will handle that correctly if you do not need a
spatial table. I did it once using ogr SQL execute from a python script.
Ther you can handle exactly what output type you need (text, table, html
result...)
View this message in context: http://osgeo-org.1560.x6.nabble.com/problem-with-GROUP-BY-in-Execute-SQL-Processing-tp5181825p5181839.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
