[Qgis-developer] problem with GROUP BY in `Execute SQL` Processing
Matteo Ghetta matteo.ghetta at gmail.com
Fri Jan 16 03:08:06 PST 2015
mmm I made some attempts but always the same parsing error..
so, you are saying that the error in Processing is related to the GEOMETRY
column right?
in the DB manager I can run the same query and then load the file when I
specify the GEOMETRY column. That's ok
But why I don't have any problem with other statements like order by?
When I ran those queries the file is correctly loaded with no GEOMETRY
specifications..
Thanks
Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150116/e9b63115/attachment.html>
