[Qgis-developer] problem with GROUP BY in `Execute SQL` Processing
Roy
royroge at outlook.com
Tue Jan 20 00:25:29 PST 2015
Hi Matteo,
I thing the problem is that "GROUP BY" is not supported on shapefile
format.
Il 16/01/2015 12.08, Matteo Ghetta ha scritto:
> mmm I made some attempts but always the same parsing error..
> so, you are saying that the error in Processing is related to the
> GEOMETRY column right?
> in the DB manager I can run the same query and then load the file when
> I specify the GEOMETRY column. That's ok
> But why I don't have any problem with other statements like order by?
> When I ran those queries the file is correctly loaded with no GEOMETRY
> specifications..
> Thanks
> Matteo
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150120/96f27309/attachment-0001.html>
