[Qgis-developer] problem with GROUP BY in `Execute SQL` Processing
Jürgen E. Fischer
jef at norbit.de
Tue Jan 20 00:38:58 PST 2015
Hi Matteo,
On Fri, 16. Jan 2015 at 10:48:16 +0100, Matteo Ghetta wrote:
> I'm trying to run the Processing Execute SQL algorithm with super simple
> following query:
> select * from au where ID > 100 group by ID
Um, is ID the only column? Otherwise I'd expect that it needs to be
(as it would be undefined what to return for the other columns):
select id from au where id > 100 group by ID
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150120/69fcd4ca/attachment.pgp>
