[Qgis-developer] Processing disappeared from QGIS master?
Victor Olaya volayaf at gmail.com
Mon Jan 19 13:47:09 PST 2015
If you are running linux, there should be no path to select, that's
normal. It looks like it finds no saga in your system, maybe it is
making a wrong call when trying to find out the installed version.
I assume you have SAGA installed and in your PATH...
2015-01-19 17:25 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 19/01/2015 17:24, Victor Olaya ha scritto:
>> Any error trace?
> No error, in the settings the saga provider is marked as "none", no path
> is selectable, and no saga algs are visible in the box.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
