[Qgis-developer] Processing disappeared from QGIS master?
Paolo Cavallini
cavallini at faunalia.it
Mon Jan 19 22:50:43 PST 2015
Il 19/01/2015 22:47, Victor Olaya ha scritto:
> If you are running linux, there should be no path to select, that's
> normal. It looks like it finds no saga in your system, maybe it is
> making a wrong call when trying to find out the installed version.
Hi Victor,
sorry, my mistake, sorry for the noise. However, now running saga throws
an error.
All the best, and thanks.
SAGA execution console output
Error: Grid file could not be opened.
Error: input file
[/tmp/processing/590b940599c64f3ab5054d672a250297/dtm.sgrd]
Error: Elevation
____________________________
SAGA Version: 2.1.4
library path: /usr/lib/x86_64-linux-gnu/saga/
library name: libta_morphometry
library : Morphometry
tool : Slope, Aspect, Curvature
author : O.Conrad (c) 2001
processors : 4 [4]
Load grid: /tmp/processing/590b940599c64f3ab5054d672a250297/dtm.sgrd...
failed
Usage: saga_cmd ta_morphometry 0 -ELEVATION <str> [-SLOPE <str>]
[-ASPECT <str>] [-C_GENE <str>] [-C_PROF <str>] [-C_PLAN <str>] [-C_TANG
<str>] [-C_LONG <str>] [-C_CROS <str>] [-C_MINI <str>] [-C_MAXI <str>]
[-C_TOTA <str>] [-C_ROTO <str>] [-METHOD <str>] [-UNIT_SLOPE <str>]
[-UNIT_ASPECT <str>]
-ELEVATION:<str> Elevation
Grid (input)
-SLOPE:<str> Slope
Grid (output)
-ASPECT:<str> Aspect
Grid (output)
-C_GENE:<str> General Curvature
Grid (optional output)
-C_PROF:<str> Profile Curvature
-C_PLAN:<str> Plan Curvature
-C_TANG:<str> Tangential Curvature
-C_LONG:<str> Longitudinal Curvature
-C_CROS:<str> Cross-Sectional Curvature
-C_MINI:<str> Minimal Curvature
-C_MAXI:<str> Maximal Curvature
-C_TOTA:<str> Total Curvature
-C_ROTO:<str> Flow Line Curvature
-METHOD:<str> Method
Choice
Available Choices:
[0] maximum slope (Travis et al. 1975)
[1] maximum triangle slope (Tarboton 1997)
[2] least squares fitted plane (Horn 1981, Costa-Cabral & Burgess 1996)
[3] 6 parameter 2nd order polynom (Evans 1979)
[4] 6 parameter 2nd order polynom (Heerdegen & Beran 1982)
[5] 6 parameter 2nd order polynom (Bauer, Rohdenburg, Bork 1985)
[6] 9 parameter 2nd order polynom (Zevenbergen & Thorne 1987)
[7] 10 parameter 3rd order polynom (Haralick 1983)
Default: 6
-UNIT_SLOPE:<str> Slope Units
Choice
Available Choices:
[0] radians
[1] degree
[2] percent
Default: 0
-UNIT_ASPECT:<str> Aspect Units
Choice
Available Choices:
[0] radians
[1] degree
Default: 0
Error: executing tool [GDAL: Export Raster]
SAGA Version: 2.1.4
library name: libio_gdal
library : GDAL/OGR
tool : GDAL: Export Raster
author : O.Conrad (c) 2007
processors : 4 [4]
Load grid:
/tmp/processing/e42f70bc0aa64d2398a3516251b52381/SLOPE.tif.sgrd...
failed
GDAL: Export Raster: could not initialize data objects
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/54c709d08eb743a3a2023b874ba1ab78/ASPECT.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/17db4faead0f49e690306892f88f1e33/CGENE.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/08f2acea222441d3baf0946416a93746/CPLAN.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/c19994f68f944563b2bb3725c8ad0880/CPROF.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/56d46c7e7e6b4150bf49fbe8333a62c6/CTANG.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/38c785a832ea493c8804d2daca550d36/CLONG.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/e453968794104919ba438826b053c3d3/CCROS.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/abae501b927347739a2226fd94f5c238/CMINI.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/5f5b643e658f49bfb619b2d8e5d5de5c/CMAXI.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/122c59952f9c4c8e950be9d1e72755ed/CTOTA.tif.sgrd...
failed
SAGA Version: 2.1.4
library : GDAL/OGR
processors : 4 [4]
Load grid:
/tmp/processing/9f6225e79ead451d88b568e37fa67c1c/CROTO.tif.sgrd...
failed
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
