[Qgis-developer] guestimating plug-in dev time?
Rémi Cura remi.cura at gmail.com
Tue Jan 20 00:36:59 PST 2015
Many thanks for all the answers !
The new version (2.6) is way more stable than 2.3 regarding postgis table.
I'll do some torture test and submit tickets if I find any problem.
Cheers,
Rémi-C
2015-01-19 13:31 GMT+01:00 George Silva <georger.silva at gmail.com>:
> I also have a lot of experience with a large number of users (around 15)
> editing a central database with PostGIS. No problems there.
> Remi, the development time for this would be around a day. If you wish to
> outsource that job, I have some experience with QGIS Plugins and I could
> develop that for you.
> George
> On Mon, Jan 19, 2015 at 10:29 AM, Bernhard Ströbl <
> bernhard.stroebl at jena.de> wrote:
>> Hi Andreas,
>> I do not think that multi-core rendering is the issue here as Remi
>> mentions to have experienced crashes since QGIS 1.8.
>> Remi,
>> I am using QGIS with Postgres/PostGIS with some dozens of users on a
>> central database _without_ any issues in QGIS (except the multi-core issue
>> Andreas mentioned). So do share your problems together with relevent parts
>> of your data base so they can beanalyzed.
>> Bernhard
>> Am 19.01.2015 13:19, schrieb Andreas Neumann:
>>> Hi Remi,
>>> Regarding crashes with Postgis: do you have multithreading with a lot of
>>> CPU cores active? I am experiencing crashes if more than 2 cores are
>>> active. Try limiting to 2 CPU cores and see if this helps.
>>> Still trying to investigate this issue with the devs.
>>> Besides the above issue, editing with Postgis works stable for me -
>>> certainly not as many crashes as you say you have.
>>> Please do not ignore the crashes but try to report them so that the devs
>>> can do something about it.
>>> Andreas
>>> On 19.01.2015 11:57, Rémi Cura wrote:
>>>> I think a more global solution is possible.
>>>> After all when you load a postgis layer in qgis, if somebody else
>>>> changes it, the view is not refreshed, which is annoying (and
>>>> sometimes dangerous because you may edit old data).
>>>> It would be easy to ad this (which would also work for my case) using
>>>> the LISTEN / NOTIFY feature of postgres.
>>>> Basically when selecting a table as a new qgis layer, you
>>>> automatically add a triger to it.
>>>> The trigger will be fired at any change (create/delete/update).
>>>> The trigger would simply send a message to qgis via NOTIFY.
>>>> example : "NOTIFY qgis_change_XXXX ;", where XXXX is a unique id.
>>>> Of course qgis would be listening, which is very simple in python
>>>> (import psycopg2;
>>>> conn = psycopg.connect(my_database_string)
>>>> conn.autocommit(1)
>>>> curs = conn.cursor()
>>>> curs.execute("LISTEN qgis_change_XXXX;"))
>>>> Of course one would need a mechanism to remove this trigger when not
>>>> necessary (for instance, name the channel "qgis_change_/time_stamp/",
>>>> delete channel too old automatically, and change channel periodically
>>>> (20 in for instance)).
>>>> I don't know if from a security point of view it would be possibe
>>>> tough (would require the permission to create a trigger).
>>>> I don't know if typical qgis user have the right to create trigger on
>>>> database they use.
>>>> I use a lot of different version of QGIS and I can guarantee at least
>>>> a dozen crash a day with version 1.8 to 2.3,
>>>> plus pending transaction with postgis whenever the crash occurs.
>>>> I'm installing 2.6 to see if postgis layers are less fragile right now
>>>> Cheers,
>>>> Rémi-C
>>>> 2015-01-19 11:29 GMT+01:00 Martin Dobias <wonder.sk at gmail.com
>>>> <mailto:wonder.sk at gmail.com>>:
>>>>     I see - indeed QGIS would need to do quite some database
>>>>     inspection to understand that layer A and layer B are related.
>>>>     This should be however also easy to address in a custom plugin.
>>>>     It is surprising to me that you say PostGIS layers are fragile in
>>>>     QGIS - they are very commonly used by lots of people and we
>>>>     haven't heard about crashes in the issue tracker. If you do
>>>>     experience crashes please consider filing reports on hub.qgis.org
>>>>     <http://hub.qgis.org> with instructions on how to replicate them.
>>>>     Regards
>>>>     Martin
>>>>     On Mon, Jan 19, 2015 at 5:18 PM, Rémi Cura <remi.cura at gmail.com
>>>>     <mailto:remi.cura at gmail.com>> wrote:
>>>>         Thanks Martin,
>>>>         one day to several days feel like a very reasonnable order of
>>>>         magnitude.
>>>>         QGis is not refreshing the view because when editing layer A
>>>>         the postgis data base automatically also edit layer B.
>>>>         I don't think qgis has a mechanism of tracking dbchanges (it
>>>>         would be possible tough).
>>>>         Morevover PostGIS layer are still "fragile" in qgis (crashes
>>>>         often).
>>>>         Thanks for the help,
>>>>         Cheers
>>>>         Rémi-C
>>>>         2015-01-19 10:56 GMT+01:00 Martin Dobias <wonder.sk at gmail.com
>>>>             Hi Remi
>>>>             Such plugin should be quite easy to write - I would assume
>>>>             up to one day of work for an experienced pyqgis developer.
>>>>             For a newcomer it may take few more days to get familiar
>>>>             with the API, tools, environment and so on.
>>>>             For the refresh of rendering after geometry editing - that
>>>>             should work out of the box and I would consider it a bug
>>>>             if it does not.
>>>>             Regards
>>>>             Martin
>>>>             On Mon, Jan 19, 2015 at 3:16 PM, Rémi Cura
>>>>             <remi.cura at gmail.com <mailto:remi.cura at gmail.com>> wrote:
>>>>                 Hello dear list.
>>>>                 I'm usually active on the postgis or postgres list,
>>>>                 but today I would like to ask a question regarding dev
>>>>                 time.
>>>>                 In your opinion,
>>>>                 How much time would be needed to write a plugin for
>>>>                 multiple versions of qgis (2.2 to current 2.6) doing 3
>>>>                 simple things :
>>>>                  - auto commit the edition of geometry when in edition
>>>>                 mode (no need to click on save  changes each time)
>>>>                  - force refresh of rendering after edition of a
>>>> geometry
>>>>                  - every camera changes (zoom or position), send a sql
>>>>                 query containing user name and geometry of view (a
>>>>                 rectangle in wkt for instance).
>>>>                 I can estimate this at my poor qgis-dev level, but I
>>>>                 would like to have the timing for an expert qgis dev.
>>>>                 Many thanks,
>>>>                 Remi-C
>>>>                 _______________________________________________
>>>>                 Qgis-developer mailing list
>>>>                 Qgis-developer at lists.osgeo.org
>>>>                 <mailto:Qgis-developer at lists.osgeo.org>
>>>>                 http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> __________ Information from ESET Mail Security, version of virus
>> signature database 11036 (20150119) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> George R. C. Silva
> SIGMA Consultoria
> http://www.consultoriasigma.com.br/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150120/03555686/attachment.html>
