[Qgis-developer] guestimating plug-in dev time?
Andreas Neumann
a.neumann at carto.net
Tue Jan 20 00:46:49 PST 2015
Hi Rémi,
Good to hear. Note that 2.3 was the dev version and not the stable
version. 2.4 was stable, then 2.6, 2.8, etc.
Andreas
On 20.01.2015 09:36, Rémi Cura wrote:
> Many thanks for all the answers !
> The new version (2.6) is way more stable than 2.3 regarding postgis table.
> I'll do some torture test and submit tickets if I find any problem.
> Cheers,
> Rémi-C
> 2015-01-19 13:31 GMT+01:00 George Silva <georger.silva at gmail.com
> <mailto:georger.silva at gmail.com>>:
> I also have a lot of experience with a large number of users
> (around 15) editing a central database with PostGIS. No problems
> there.
> Remi, the development time for this would be around a day. If you
> wish to outsource that job, I have some experience with QGIS
> Plugins and I could develop that for you.
> George
> On Mon, Jan 19, 2015 at 10:29 AM, Bernhard Ströbl
> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>> wrote:
> Hi Andreas,
> I do not think that multi-core rendering is the issue here as
> Remi mentions to have experienced crashes since QGIS 1.8.
> Remi,
> I am using QGIS with Postgres/PostGIS with some dozens of
> users on a central database _without_ any issues in QGIS
> (except the multi-core issue Andreas mentioned). So do share
> your problems together with relevent parts of your data base
> so they can beanalyzed.
> Bernhard
> Am 19.01.2015 13:19, schrieb Andreas Neumann:
> Hi Remi,
> Regarding crashes with Postgis: do you have multithreading
> with a lot of
> CPU cores active? I am experiencing crashes if more than 2
> cores are
> active. Try limiting to 2 CPU cores and see if this helps.
> Still trying to investigate this issue with the devs.
> Besides the above issue, editing with Postgis works stable
> for me -
> certainly not as many crashes as you say you have.
> Please do not ignore the crashes but try to report them so
> that the devs
> can do something about it.
> Andreas
> On 19.01.2015 11:57, Rémi Cura wrote:
> I think a more global solution is possible.
> After all when you load a postgis layer in qgis, if
> somebody else
> changes it, the view is not refreshed, which is
> annoying (and
> sometimes dangerous because you may edit old data).
> It would be easy to ad this (which would also work for
> my case) using
> the LISTEN / NOTIFY feature of postgres.
> Basically when selecting a table as a new qgis layer, you
> automatically add a triger to it.
> The trigger will be fired at any change
> (create/delete/update).
> The trigger would simply send a message to qgis via
> NOTIFY.
> example : "NOTIFY qgis_change_XXXX ;", where XXXX is a
> unique id.
> Of course qgis would be listening, which is very
> simple in python
> (import psycopg2;
> conn = psycopg.connect(my_database_string)
> conn.autocommit(1)
> curs = conn.cursor()
> curs.execute("LISTEN qgis_change_XXXX;"))
> Of course one would need a mechanism to remove this
> trigger when not
> necessary (for instance, name the channel
> "qgis_change_/time_stamp/",
> delete channel too old automatically, and change
> channel periodically
> (20 in for instance)).
> I don't know if from a security point of view it would
> be possibe
> tough (would require the permission to create a trigger).
> I don't know if typical qgis user have the right to
> create trigger on
> database they use.
> I use a lot of different version of QGIS and I can
> guarantee at least
> a dozen crash a day with version 1.8 to 2.3,
> plus pending transaction with postgis whenever the
> crash occurs.
> I'm installing 2.6 to see if postgis layers are less
> fragile right now ^^
> Cheers,
> Rémi-C
> 2015-01-19 11:29 GMT+01:00 Martin Dobias
> <wonder.sk at gmail.com <mailto:wonder.sk at gmail.com>
> <mailto:wonder.sk at gmail.com>>>:
> I see - indeed QGIS would need to do quite some
> database
> inspection to understand that layer A and layer B
> are related.
> This should be however also easy to address in a
> custom plugin.
> It is surprising to me that you say PostGIS layers
> are fragile in
> QGIS - they are very commonly used by lots of
> people and we
> haven't heard about crashes in the issue tracker.
> If you do
> experience crashes please consider filing reports
> on hub.qgis.org <http://hub.qgis.org>
> <http://hub.qgis.org> with instructions on how to
> replicate them.
> Regards
> Martin
> On Mon, Jan 19, 2015 at 5:18 PM, Rémi Cura
> <remi.cura at gmail.com <mailto:remi.cura at gmail.com>
> <mailto:remi.cura at gmail.com>>> wrote:
> Thanks Martin,
> one day to several days feel like a very
> reasonnable order of
> magnitude.
> QGis is not refreshing the view because when
> editing layer A
> the postgis data base automatically also edit
> layer B.
> I don't think qgis has a mechanism of tracking
> dbchanges (it
> would be possible tough).
> Morevover PostGIS layer are still "fragile" in
> qgis (crashes
> often).
> Thanks for the help,
> Cheers
> Rémi-C
> 2015-01-19 10:56 GMT+01:00 Martin Dobias
> Hi Remi
> Such plugin should be quite easy to write
> - I would assume
> up to one day of work for an experienced
> pyqgis developer.
> For a newcomer it may take few more days
> to get familiar
> with the API, tools, environment and so on.
> For the refresh of rendering after
> geometry editing - that
> should work out of the box and I would
> consider it a bug
> if it does not.
> Regards
> Martin
> On Mon, Jan 19, 2015 at 3:16 PM, Rémi Cura
> Hello dear list.
> I'm usually active on the postgis or
> postgres list,
> but today I would like to ask a
> question regarding dev
> time.
> In your opinion,
> How much time would be needed to write
> a plugin for
> multiple versions of qgis (2.2 to
> current 2.6) doing 3
> simple things :
> - auto commit the edition of geometry
> when in edition
> mode (no need to click on save
> changes each time)
> - force refresh of rendering after
> edition of a geometry
> - every camera changes (zoom or
> position), send a sql
> query containing user name and
> geometry of view (a
> rectangle in wkt for instance).
> I can estimate this at my poor
> qgis-dev level, but I
> would like to have the timing for an
> expert qgis dev.
> Many thanks,
> Remi-C
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> <mailto:Qgis-developer at lists.osgeo.org>>
> __________ Information from ESET Mail Security, version of
> virus signature database 11036 (20150119) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> George R. C. Silva
> SIGMA Consultoria
> http://www.consultoriasigma.com.br/
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150120/e4ecd3c7/attachment-0001.html>
