[Qgis-developer] Processing disappeared from QGIS master?
Giovanni Manghi
giovanni.manghi at gmail.com
Tue Jan 20 02:55:55 PST 2015
> No problem. Actually, that "None" version shouldn't appear, i ahve
> added a small fix to improve that version detection
> The error you are getting seems to be caused by SAGA believing that a
> layer is already exported, so it is not calling the export routines
> before calling the algorithm itself. I had seen this before, and I
> have now added a fix for it.
> All this changes are applied in this commit
> https://github.com/qgis/QGIS/commit/e9228b67c934f4eaeae0beb8a033916f5317318f
> Hope this helps
Hi Victor,
I tested also under Window, from the command line (no Processing
involved, but of course affected) and SAGA 2.1.4 io_gdal also fails
when
saga_cmd io_gdal 0 -TRANSFORM...
while
saga_cmd io_gdal -TRANSFORM...
works
cheers
-- G --
