[Qgis-developer] Processing disappeared from QGIS master?
Victor Olaya
volayaf at gmail.com
Tue Jan 20 03:10:29 PST 2015
True, I was confusing versions. The "normal" syntax does not work with 2.1.4.
This is weird, because you need to indicate the algorithm to use...so
without that 0 it shouldn't work. Another one of this annoying SAGA
mysteries....
I will fix that call to gdal_io. Other modules, however, seems to
accept the algorithm index/name correctly. I tried the export passing
the algorithm name instead of 0, and it also fails
Thanks for your help!
BTW, did anyone find SAGA 2.1.4 to be extremely slow?. It takes a lot
of time to launch SAGA before it starts doing the actual computing,
there is a huge overhead. With several calls per Processing algorithm,
the time it takes to run is rather long...
2015-01-20 11:55 GMT+01:00 Giovanni Manghi <giovanni.manghi at gmail.com>:
>> No problem. Actually, that "None" version shouldn't appear, i ahve
>> added a small fix to improve that version detection
>> The error you are getting seems to be caused by SAGA believing that a
>> layer is already exported, so it is not calling the export routines
>> before calling the algorithm itself. I had seen this before, and I
>> have now added a fix for it.
>> All this changes are applied in this commit
>> https://github.com/qgis/QGIS/commit/e9228b67c934f4eaeae0beb8a033916f5317318f
>> Hope this helps
> Hi Victor,
> I tested also under Window, from the command line (no Processing
> involved, but of course affected) and SAGA 2.1.4 io_gdal also fails
> when
> saga_cmd io_gdal 0 -TRANSFORM...
> while
> saga_cmd io_gdal -TRANSFORM...
> works
> cheers
> -- G --
