[Qgis-developer] SPIT still functional?
Olivier Dalang olivier.dalang at gmail.com
Tue Jan 20 10:01:30 PST 2015
Oops I forgot the link to the branch with the small update on the db
manager :
https://github.com/olivierdalang/QGIS/tree/db_manager_dialog_on_import
2015-01-20 17:59 GMT+00:00 Olivier Dalang <olivier.dalang at gmail.com>:
> Hi,
> As I said on the user list ( thread : "Import (not so) large data into a
> remote postgis database" ), SPIT has the advantage of showing a progress
> bar.
> This is a good feature when uploading data through a slow connection (my
> case these days).
> But I think it would make sense to move this feature (the progress bar) to
> the DB manager.
> I tried to do it [1], and it kind of works sometimes, but there's some UI
> refreshing issues, and I won't time to investigate much more these days...
> Maybe we should also think about making the import more efficient and
> robust. I'm currently working with a slow connection, and uploading a table
> of around 4000 lines takes ages (around 2 hours).
> I don't really understand what the bottleneck is, but the transfer rate is
> way under the transfer rate I'd have if I uploaded a dump file and ran it
> online.
> All more efficient ways (pg_dump, ogr2ogr, pgdump,...) are not suited for
> non power users...
> Bests,
> Olivier
> 2015-01-20 14:40 GMT+00:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Hi all,
>> is SPIT plugin still functional? Still useful?
>> AFAIK its main advantage is the possibility of importing multiple files
>> (but a Processing module is now available for this), and speed.
>> IMHO this is a good time to evaluate whether we want to drop some parts.
>> All the best.
>> Paolo Cavallini - www.faunalia.eu
>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150120/aa6f7961/attachment.html>
