[Qgis-developer] [gdal-dev] Compiling QGIS on ubuntu 14.10 - Couldn't load PyQGIS" error
Zoltan Szecsei
zoltans at geograph.co.za
Tue Jan 20 22:32:00 PST 2015
I've gone through the recommended process
(http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html)
I had a problem with Grass, but set "with grass" in ccmake to "No" and that solved that (for now).
After firing up QGIS, I get the dreaded "Couldn't load PyQGIS" error.
My Python is installed from the default ubuntu 14.10 repository, and is presumably the wrong version for QGIS 2.7.0 Master.
Is this a python version issue, and which version (from where) do I need?
I did my anonymous git check out a week ago - could this also be part of the issue?
Thanks in advance,
Zoltan.
QGIS version 2.7.0-Master QGIS code
revision exported
Compiled against Qt 4.8.6 Running against
Qt 4.8.6
Compiled against GDAL/OGR 1.11.1 Running against
GDAL/OGR 1.11.1
Compiled against GEOS 3.4.2-CAPI-1.8.2 Running against
GEOS 3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version 9.4rc1 SpatiaLite Version 4.1.1
QWT Version 5.2.3 PROJ.4 Version
480
QScintilla2 Version 2.8.3
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150121/d2f6e5f2/attachment.html>
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
