[Qgis-developer] Re : Problem when using spatial index
Junior
delazj at gmail.com
Wed Jan 21 04:23:03 PST 2015
And if you delete the .qix before saving? And then recreate it...
Envoyé depuis mon HTC
----- Reply message -----
De : "Nejia Ben Nasr" <nejia.bennasr at spaceyes3d.com>
Pour : "'Junior Delaz'" <delazj at gmail.com>
Cc : "'qgis-developer'" <qgis-developer at lists.osgeo.org>
Objet : [Qgis-developer] Problem when using spatial index
Date : mer., janv. 21, 2015 13:14
I already tried to save to anther shapefile and edit it (add, modify, remove features …) the .qix was automatically created and I get the same problem Thanks,Nejia De : Junior Delaz [mailto:delazj at gmail.com]
Envoyé : mercredi 21 janvier 2015 12:21
À : Nejia Ben Nasr
Cc : qgis-developer
Objet : Re: [Qgis-developer] Problem when using spatial index Some users [1] have already encountered this issue and i understood that it may be related to non correspondance between the number of rows in the .dbf file and number of geometry (some rows had no geometry). A simple "Save As.." to another shapefile has solved the problem.
[1] http://georezo.net/forum/viewtopic.php?id=95143 (in french, sorry )
2015-01-21 9:16 GMT+01:00 Nejia Ben Nasr <nejia.bennasr at spaceyes3d.com>:Hi, Do you think that this problem is often caused by geometry problems? Thanks,Nejia De : Junior [mailto:delazj at gmail.com]
Envoyé : mardi 20 janvier 2015 13:41
À : Nejia Ben Nasr; 'qgis-developer'
Objet : Re : [Qgis-developer] Problem when using spatial index
Nejia, what about the validity of the geometry of your features? You can check with the tool in Vector menu > Geometry tools > check geometry validity
Pour : "'qgis-developer'" <qgis-developer at lists.osgeo.org>
Date : mar., janv. 20, 2015 13:03
I use QGIS 2.6.1 De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Nejia Ben Nasr
Envoyé : mardi 20 janvier 2015 09:39
À : qgis-developer
Hi all, I load a shapefile, then I create a spatial index to maximize speed of zoom and navigate in the map.The problem is: when I zoom to any area feature appear and other doesn’t.And it seems To me that the spatial index is automatically created even when I delete the .qix file Best regards,Nejia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150121/5213e8ef/attachment-0001.html>
