[Qgis-developer] Problem when using spatial index
Nejia Ben Nasr
nejia.bennasr at spaceyes3d.com
Wed Jan 21 04:30:21 PST 2015
Yes, even if I delete the .qix before saving !!
Thanks,
Nejia
De : Junior [mailto:delazj at gmail.com]
Envoyé : mercredi 21 janvier 2015 13:23
À : Nejia Ben Nasr
Cc : 'qgis-developer'
Objet : Re : [Qgis-developer] Problem when using spatial index
And if you delete the .qix before saving? And then recreate it...
Envoyé depuis mon HTC
----- Reply message -----
De : "Nejia Ben Nasr" <nejia.bennasr at spaceyes3d.com>
Pour : "'Junior Delaz'" <delazj at gmail.com>
Cc : "'qgis-developer'" <qgis-developer at lists.osgeo.org>
Objet : [Qgis-developer] Problem when using spatial index
Date : mer., janv. 21, 2015 13:14
I already tried to save to anther shapefile and edit it (add, modify, remove features …) the .qix was automatically created and I get the same problem
Thanks,
Nejia
De : Junior Delaz [mailto:delazj at gmail.com]
Envoyé : mercredi 21 janvier 2015 12:21
À : Nejia Ben Nasr
Cc : qgis-developer
Objet : Re: [Qgis-developer] Problem when using spatial index
Some users [1] have already encountered this issue and i understood that it may be related to non correspondance between the number of rows in the .dbf file and number of geometry (some rows had no geometry). A simple "Save As.." to another shapefile has solved the problem.
[1] http://georezo.net/forum/viewtopic.php?id=95143 (in french, sorry )
2015-01-21 9:16 GMT+01:00 Nejia Ben Nasr <nejia.bennasr at spaceyes3d.com>:
Do you think that this problem is often caused by geometry problems?
Thanks,
Nejia
Envoyé : mardi 20 janvier 2015 13:41
À : Nejia Ben Nasr; 'qgis-developer'
Nejia, what about the validity of the geometry of your features? You can check with the tool in Vector menu > Geometry tools > check geometry validity
De : "Nejia Ben Nasr" < <mailto:nejia.bennasr at spaceyes3d.com> nejia.bennasr at spaceyes3d.com>
Pour : "'qgis-developer'" < <mailto:qgis-developer at lists.osgeo.org> qgis-developer at lists.osgeo.org>
Date : mar., janv. 20, 2015 13:03
I use QGIS 2.6.1
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Nejia Ben Nasr
Envoyé : mardi 20 janvier 2015 09:39
À : qgis-developer
Hi all,
I load a shapefile, then I create a spatial index to maximize speed of zoom and navigate in the map.
The problem is: when I zoom to any area feature appear and other doesn’t.
And it seems To me that the spatial index is automatically created even when I delete the .qix file
Best regards,
Nejia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150121/01f0ba1c/attachment.html>
