[Qgis-developer] Couldn't load PyQGIS error after compile
Zoltan Szecsei zoltans at geograph.co.za
Wed Jan 21 08:18:38 PST 2015
Sorry - forgot to add:
    root at gs01:/home/geograph# dpkg -l | grep -i qgis
    ii  libqgis-analysis2.7.0 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS - shared analysis library
    ii  libqgis-core2.7.0 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS - shared core library
    ii  libqgis-customwidgets 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS custom widgets for Qt Designer
    ii  libqgis-gui2.7.0 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS - shared gui library
    ii  libqgis-networkanalysis2.7.0
    2.7.0+git20150120+51bb803~utopic1        amd64        QGIS - shared
    network analysis library
    ii  libqgis-server2.7.0 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS - shared server library
    ii  libqgisgrass2.7.0 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS - shared grass library
    ii  libqgispython2.7.0 2.7.0+git20150120+51bb803~utopic1
    amd64        QGIS - shared Python library
    ii  python-qgis 2.7.0+git20150120+51bb803~utopic1
    amd64        Python bindings to QGIS
    ii  python-qgis-common 2.7.0+git20150120+51bb803~utopic1
    all          Python bindings to QGIS - architecture-independent files
    ii  qgis 2.7.0+git20150120+51bb803~utopic1        amd64
    Geographic Information System (GIS)
    ii  qgis-common 2.7.0+git20150120+51bb803~utopic1
    all          QGIS - architecture-independent data
    ii  qgis-plugin-globe 2.7.0+git20150120+51bb803~utopic1
    amd64        OSG globe plugin for QGIS
    ii  qgis-plugin-globe-common
    2.7.0+git20150120+51bb803~utopic1        all          OSG globe
    plugin for QGIS - architecture-independent data
    ii  qgis-plugin-grass 2.7.0+git20150120+51bb803~utopic1
    amd64        GRASS plugin for QGIS
    ii  qgis-plugin-grass-common
    2.7.0+git20150120+51bb803~utopic1        all          GRASS plugin
    ii  qgis-providers 2.7.0+git20150120+51bb803~utopic1
    amd64        collection of data providers to QGIS
    ii  qgis-providers-common 2.7.0+git20150120+51bb803~utopic1
    all          collection of data providers to QGIS -
On 01/21/2015 06:13 PM, Zoltan Szecsei wrote:
> Hi,
> I've gone through the recommended process
> (http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html)
> I had a problem with Grass, but set "with grass" in ccmake to "No" and that solved that (for now).
> After firing up QGIS, I get the dreaded "Couldn't load PyQGIS" error.
> My Python is installed from the default ubuntu 14.10 repository, and is presumably the wrong version for QGIS 2.7.0 Master.
> Is this a python version issue, and which version (from where) do I need?
> I did my anonymous git check out a week ago - could this also be part of the issue?
> Thanks in advance,
> Zoltan.
>     QGIS version                 2.7.0-Master QGIS code
>     revision        exported
>     Compiled against Qt          4.8.6              Running against
>     Qt        4.8.6
>     Compiled against GDAL/OGR    1.11.1             Running against
>     GDAL/OGR  1.11.1
>     Compiled against GEOS        3.4.2-CAPI-1.8.2   Running against
>     GEOS      3.4.2-CAPI-1.8.2 r3921
>     PostgreSQL Client Version    9.4rc1 SpatiaLite Version        4.1.1
>     QWT Version                  5.2.3              PROJ.4 Version
>             480
>     QScintilla2 Version          2.8.3
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax:    +27-86-6115323www.geograph.co.za
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150121/0443320c/attachment.html>
