[Qgis-developer] Exact print composing
Zoltan Szecsei zoltans at geograph.co.za
Tue Jan 27 06:41:17 PST 2015
Yes - I saw that button. Thanks for the heads-up.
Z
On 2015/01/27 16:39, Andreas Neumann wrote:
> Hi Zoltan,
> Once you exactly positioned elements - you may want to lock them, so
> they don't get moved accidentally. With the new item list that Nyall
> introduced recently you can easily lock/unlock elements from this item
> list.
> Andreas
> On 27.01.2015 15:28, Zoltan Szecsei wrote:
>> On 2015/01/27 16:16, Andreas Neumann wrote:
>>> Hi Zoltan,
>>> Every object in the print composer can be positioned/scaled with
>>> exact numbers - have a look at the "Position and Size" group of
>>> every items properties. This has been around since ages (at least
>>> since version 1.7).
>>> Alternatively/in addition you can also use snappable grids and
>>> guidelines.
>>> Hope this helps?
>> Exactly what I want - This is only the second time I'm needing to use
>> the composer, and the first time I only needed a dump print, so
>> didn't bother to fiddle with the options.
>> This time, when I added the map to the composer and saw it was wonky,
>> I deleted it and started looking for plugins before noticing the
>> "Item Properties" tab.
>> Big thanks,
>> Zoltan
>>> Andreas
>>> On 27.01.2015 15:10, Zoltan Szecsei wrote:
>>>> Hi,
>>>> Is there a way to set exact print composer sizes and map positions?
>>>> I have set a composer canvas size of 460mm by 275mm, and an area of
>>>> interest (made up of one cropped raster and 12 cropped vector maps)
>>>> that is exactly that size, at 1:500 scale.
>>>> Adding this to print composer canvas using a mouse is not exactly
>>>> accurate. I've searched plugins, but noticed nothing useful.
>>>> Does print composer by any chance create a text file that I can
>>>> hack to achieve this?
>>>> Regards,
>>>> Zoltan
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
