[Qgis-developer] Exact print composing
Andreas Neumann a.neumann at carto.net
Tue Jan 27 06:39:38 PST 2015
Hi Zoltan,
Once you exactly positioned elements - you may want to lock them, so
they don't get moved accidentally. With the new item list that Nyall
introduced recently you can easily lock/unlock elements from this item list.
Andreas
On 27.01.2015 15:28, Zoltan Szecsei wrote:
> On 2015/01/27 16:16, Andreas Neumann wrote:
>> Hi Zoltan,
>> Every object in the print composer can be positioned/scaled with
>> exact numbers - have a look at the "Position and Size" group of every
>> items properties. This has been around since ages (at least since
>> version 1.7).
>> Alternatively/in addition you can also use snappable grids and
>> guidelines.
>> Hope this helps?
> Exactly what I want - This is only the second time I'm needing to use
> the composer, and the first time I only needed a dump print, so didn't
> bother to fiddle with the options.
> This time, when I added the map to the composer and saw it was wonky,
> I deleted it and started looking for plugins before noticing the "Item
> Properties" tab.
> Big thanks,
> Zoltan
>> Andreas
>> On 27.01.2015 15:10, Zoltan Szecsei wrote:
>>> Hi,
>>> Is there a way to set exact print composer sizes and map positions?
>>> I have set a composer canvas size of 460mm by 275mm, and an area of
>>> interest (made up of one cropped raster and 12 cropped vector maps)
>>> that is exactly that size, at 1:500 scale.
>>> Adding this to print composer canvas using a mouse is not exactly
>>> accurate. I've searched plugins, but noticed nothing useful.
>>> Does print composer by any chance create a text file that I can hack
>>> to achieve this?
>>> Regards,
>>> Zoltan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
