[Qgis-developer] Looping over features in processing
Tim Sutton
tim at qgis.org
Fri Jul 24 09:40:33 PDT 2015
Hi
> On 23 Jul 2015, at 22:44, Tim Sutton <tim at qgis.org> wrote:
> Hi Victor
>> On 23 Jul 2015, at 22:18, Victor Olaya <volayaf at gmail.com <mailto:volayaf at gmail.com>> wrote:
>> Tim
>> What you are describing is the behaviour of the iterative execution of algorithms (for a layer with n features, it runs the algorihtm n times, each of them using as input a layer with only one of those features). That can be executed without the need to code anything, from the algorithm dialog.
> Yeah that sounds exactly like what I am after. I will go and take a look at that.
Sorry to be a bit slow here - I went back to try this and couldn’t see where / how to do it - can you give a few more pointers?
Thanks!
Regards
Tim
> Thanks!
> Regards
> Tim
>> If it's not exactly what you are looking for and you want to code something similar, maybe you can at least check the corresponding code to get some ideas
>> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/AlgorithmExecutor.py#L58 <https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/AlgorithmExecutor.py#L58>
>> Let me know if you have more questions
>> Cheers
>> 2015-07-23 20:15 GMT+02:00 Tim Sutton <tim at qgis.org <mailto:tim at qgis.org>>:
>> Hi all
>> Is it possible to write loops in processing. I’d like to do stuff like iterate over each poly in a polygon layer, clip features from a few layers and write them to a subfolder whose name is based on the name of the polygon layer. Think of it like atlas but for data not for print compositions. Has anyone done something similar?
>> Regards
>> Tim
>> <PastedGraphic-1.tiff>
>> Tim Sutton
>> QGIS Project Steering Committee Member
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Tim Sutton
Tim Sutton
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150724/9cd7d9b6/attachment-0001.html>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150724/9cd7d9b6/attachment-0001.tiff>
