[Qgis-developer] Looping over features in processing
Paolo Cavallini
cavallini at faunalia.it
Fri Jul 24 10:06:55 PDT 2015
Just click on the small green arrow besides layer name.
Cheers.
Il 24 luglio 2015 18:40:33 CEST, Tim Sutton <tim at qgis.org> ha scritto:
>Hi
>> On 23 Jul 2015, at 22:44, Tim Sutton <tim at qgis.org> wrote:
>> Hi Victor
>>> On 23 Jul 2015, at 22:18, Victor Olaya <volayaf at gmail.com
><mailto:volayaf at gmail.com>> wrote:
>>> Tim
>>> What you are describing is the behaviour of the iterative execution
>of algorithms (for a layer with n features, it runs the algorihtm n
>times, each of them using as input a layer with only one of those
>features). That can be executed without the need to code anything, from
>the algorithm dialog.
>> Yeah that sounds exactly like what I am after. I will go and take a
>look at that.
>Sorry to be a bit slow here - I went back to try this and couldn’t see
>where / how to do it - can you give a few more pointers?
>Thanks!
>Regards
>Tim
>> Thanks!
>> Regards
>> Tim
>>> If it's not exactly what you are looking for and you want to code
>something similar, maybe you can at least check the corresponding code
>to get some ideas
>https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/AlgorithmExecutor.py#L58
><https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/AlgorithmExecutor.py#L58>
>>> Let me know if you have more questions
>>> Cheers
>>> 2015-07-23 20:15 GMT+02:00 Tim Sutton <tim at qgis.org
><mailto:tim at qgis.org>>:
>>> Hi all
>>> Is it possible to write loops in processing. I’d like to do stuff
>like iterate over each poly in a polygon layer, clip features from a
>few layers and write them to a subfolder whose name is based on the
>name of the polygon layer. Think of it like atlas but for data not for
>print compositions. Has anyone done something similar?
>>> Regards
>>> Tim
>>> <PastedGraphic-1.tiff>
>>> Tim Sutton
>>> QGIS Project Steering Committee Member
>>> tim at qgis.org <mailto:tim at qgis.org>
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
><mailto:Qgis-developer at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
><http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Tim Sutton
>Tim Sutton
>tim at qgis.org
Paolo Cavallini
http://www.faunalia.eu
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150724/9bfa85fe/attachment.html>
