[Qgis-developer] Simplified Processing interface doesn't list GRASS algos
Anita Graser anitagraser at gmx.at
Wed Jul 29 07:07:57 PDT 2015
​Thanks​ for the clarifications Victor!
> -----Oprindelig meddelelse-----
> Fra: qgis-developer-bounces at lists.osgeo.org [mailto:
> qgis-developer-bounces at lists.osgeo.org] På vegne af Victor Olaya
> if an algorithm is repeated in several backends, only one of them is added
> to the simplified interface, eliminating the need to select one of them
> (also confusing for users)
> GRASS algorithms are not featured in the simplified interface since,
> although they are wrapped as Processing algorithms and simplified as much
> as possible, you still have to know something about GRASS and its data
> structures to use them correctly and not get strange behaviour.
> If you want to use a GRASS, algorithm, I am assuming you are an advanced
> user, so you can go to the advanced interface.
​That makes sense. Maybe all it needs then is a way to communicate the user
that the algorithm they were searching for is only available in the
advanced interface. Some message along these lines could be displayed when
the user inputs the name of a GRASS algo in the search box of the
simplified interface.
That is if we decide that the simplified interface has value for certain
user groups.
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150729/d8db78f2/attachment-0001.html>
