[Qgis-developer] Failing tests
Matthias Kuhn matthias at opengis.ch
Tue Jun 2 02:31:47 PDT 2015
Hi Jürgen
On 06/02/2015 09:03 AM, Jürgen E. Fischer wrote:
> Hi Nyall,
> On Tue, 02. Jun 2015 at 13:34:56 +1000, Nyall Dawson wrote:
>> I'd be in favour of a hardline "no breaks allowed" approached. You break
>> travis, your commit gets reverted.
> -1
> A general rule doesn't make sense to me - it depends on the break.
> If you break travis, you should fix it.
For the record, can you elaborate which types of breaks should not be
fixed and/or why certain breaks should be fixed in master instead of in
a separate branch/pull request?
Regards
Matthias
