[Qgis-developer] error during compiling [libproj.so]
Werner Macho werner.macho at gmail.com
Sat Jun 6 02:12:00 PDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi!
Did you try a "make clean" in between?
How is the Makefile produced? cmake ? ccmake? Can you take a look
where PROJ_INCLUDE_DIR and PROJ_LIBRARY point to?
Where on your system is "libproj.so.0" located?
regards
Werner
On 06/06/15 11:03, Matteo Ghetta wrote:
> Hi guys, again I have some trouble when compiling qgis. This is the
> output:
> make[2]: *** No rule to make target '/usr/lib/libproj.so', needed
> by 'output/lib/libqgis_core.so.2.9.0'.  Stop.
> CMakeFiles/Makefile2:1116: recipe for target
> 'src/core/CMakeFiles/qgis_core.dir/all' failed make[1]: ***
> [src/core/CMakeFiles/qgis_core.dir/all] Error 2 Makefile:147:
> recipe for target 'all' failed make: *** [all] Error 2
> Also without compiling, I'm not able to start qgis (master or 2.8),
> I receive the following error:
> /home/ma7730/lavori/QGIS-master/build28/output/bin/qgis: error
> while loading shared libraries: libproj.so.0: cannot open shared
> object file: No such file or directory
> Is there a problem with libproj, but I have the libproj-dev
> package installed on my computer (debian testing).
> Any help is appreciated!
> Cheers
> Matteo
> _______________________________________________ Qgis-developer
> mailing list Qgis-developer at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iEYEARECAAYFAlVyuWAACgkQDAH1YiCxBgmzDwCfUpyd8ZdSCr/vx/wlj2sok3Z9
/YcAnjpRoS4grcRGpXiJbJwXV7wPWWdu
=7OOI
-----END PGP SIGNATURE-----
