[Qgis-developer] error during compiling [libproj.so]
Matteo Ghetta matteo.ghetta at gmail.com
Sat Jun 6 02:23:59 PDT 2015
Hi Werner,
thanks for the answer!
yep, I made a make clean, this is the small bash script I use to compile:
#!/bin/bash
cd ~/lavori/QGIS-master
git checkout master
git pull
cd build
make clean && make
I also tried to add the nightly repository and install the master version
from there but I get the following error:
qgis:
Depends: libproj0 (>=4.8.0) but it is not installable
... many others dependencies
In fact, the libproj0 is not available for debian testing:
sudo aptitude install libproj0
No candidate version found for libproj0
I cannot find the related package in the internet for a manual download and
installation.. Someone else experienced the same problem?
Cheers
Matteo
2015-06-06 11:12 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi!
> Did you try a "make clean" in between?
> How is the Makefile produced? cmake ? ccmake? Can you take a look
> where PROJ_INCLUDE_DIR and PROJ_LIBRARY point to?
> Where on your system is "libproj.so.0" located?
> regards
> Werner
> On 06/06/15 11:03, Matteo Ghetta wrote:
> > Hi guys, again I have some trouble when compiling qgis. This is the
> > output:
> > make[2]: *** No rule to make target '/usr/lib/libproj.so', needed
> > by 'output/lib/libqgis_core.so.2.9.0'.  Stop.
> > CMakeFiles/Makefile2:1116: recipe for target
> > 'src/core/CMakeFiles/qgis_core.dir/all' failed make[1]: ***
> > [src/core/CMakeFiles/qgis_core.dir/all] Error 2 Makefile:147:
> > recipe for target 'all' failed make: *** [all] Error 2
> > Also without compiling, I'm not able to start qgis (master or 2.8),
> > I receive the following error:
> > /home/ma7730/lavori/QGIS-master/build28/output/bin/qgis: error
> > while loading shared libraries: libproj.so.0: cannot open shared
> > object file: No such file or directory
> > Is there a problem with libproj, but I have the libproj-dev
> > package installed on my computer (debian testing).
> > Any help is appreciated!
> > Cheers
> > Matteo
> > _______________________________________________ Qgis-developer
> > mailing list Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2
> iEYEARECAAYFAlVyuWAACgkQDAH1YiCxBgmzDwCfUpyd8ZdSCr/vx/wlj2sok3Z9
> /YcAnjpRoS4grcRGpXiJbJwXV7wPWWdu
> =7OOI
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150606/8a17964a/attachment.html>
