[Qgis-developer] error during compiling [libproj.so]
Matteo Ghetta
matteo.ghetta at gmail.com
Sun Jun 7 03:42:00 PDT 2015
Hi I have tried to compile, but some problems:
* QT_Polar libraries.. I set them to OFF as suggsted in a post (else, the
compilation would not start), but, during the compilation I get this error:
In file included from
/home/ma7730/lavori/QGIS-master/src/app/qgisapp.cpp:139:0:
/home/ma7730/lavori/QGIS-master/src/app/gps/qgsgpsinformationwidget.h:27:28:
fatal error: qwt_polar_plot.h: No such file or directory
#include <qwt_polar_plot.h>
compilation terminated.
src/app/CMakeFiles/qgis.dir/build.make:1346: recipe for target
'src/app/CMakeFiles/qgis.dir/qgisapp.cpp.o' failed
make[2]: *** [src/app/CMakeFiles/qgis.dir/qgisapp.cpp.o] Error 1
CMakeFiles/Makefile2:2410: recipe for target
'src/app/CMakeFiles/qgis.dir/all' failed
make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
Makefile:146: recipe for target 'all' failed
make: *** [all] Error 2
What can I do?
Thanks!
Matteo
2015-06-06 11:41 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi!
> No need to delete the cloned QGIS repository - just "clean" the build
> directory ..
> (or remove the build directory and create it again)
> That should be enough to help you getting started again...
> regards
> Werner
> On 06/06/15 11:39, Matteo Ghetta wrote:
> > Hi Sebastiaan, thanks! So, in simple words, I can delete the QGIS
> > git cloned directory, re-clone it, create a new build directory and
> > run a new ccmake. Right?!
> > Cheers
> > Matteo
> > 2015-06-06 11:33 GMT+02:00 Sebastiaan Couwenberg
> > <sebastic at xs4all.nl <mailto:sebastic at xs4all.nl>>:
> > On 06/06/2015 11:30 AM, Matteo Ghetta wrote:
> >> So what exacly should I do? Should I re-run ccmake in order to
> >> have another list of all the paths?
> > Throw away your old build directory, recreate it and run `cmake
> > ..` from inside it.
> > Kind Regards,
> > Bas
> > _______________________________________________ Qgis-developer
> > mailing list Qgis-developer at lists.osgeo.org
> > <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2
> iEYEARECAAYFAlVywGQACgkQDAH1YiCxBgmFEQCfe9yilTx1/OrAk74T/gRI6mj3
> 8KIAn3c0qFmf3o6OW9mA/kGjMBwaVf5F
> =WPOX
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150607/02bc63d5/attachment.html>
