[Qgis-developer] error during compiling [libproj.so]
Matteo Ghetta
matteo.ghetta at gmail.com
Sun Jun 7 06:30:14 PDT 2015
Hi all,
just to let you know that I had to set WITH_POLAR to OFF and then the
compilation rans without problems.
Thanks to all!
Matteo
2015-06-07 12:42 GMT+02:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
> Hi I have tried to compile, but some problems:
> * QT_Polar libraries.. I set them to OFF as suggsted in a post (else, the
> compilation would not start), but, during the compilation I get this error:
> In file included from
> /home/ma7730/lavori/QGIS-master/src/app/qgisapp.cpp:139:0:
> /home/ma7730/lavori/QGIS-master/src/app/gps/qgsgpsinformationwidget.h:27:28:
> fatal error: qwt_polar_plot.h: No such file or directory
> #include <qwt_polar_plot.h>
> compilation terminated.
> src/app/CMakeFiles/qgis.dir/build.make:1346: recipe for target
> 'src/app/CMakeFiles/qgis.dir/qgisapp.cpp.o' failed
> make[2]: *** [src/app/CMakeFiles/qgis.dir/qgisapp.cpp.o] Error 1
> CMakeFiles/Makefile2:2410: recipe for target
> 'src/app/CMakeFiles/qgis.dir/all' failed
> make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
> Makefile:146: recipe for target 'all' failed
> make: *** [all] Error 2
> What can I do?
> Thanks!
> Matteo
> 2015-06-06 11:41 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi!
>> No need to delete the cloned QGIS repository - just "clean" the build
>> directory ..
>> (or remove the build directory and create it again)
>> That should be enough to help you getting started again...
>> regards
>> Werner
>> On 06/06/15 11:39, Matteo Ghetta wrote:
>> > Hi Sebastiaan, thanks! So, in simple words, I can delete the QGIS
>> > git cloned directory, re-clone it, create a new build directory and
>> > run a new ccmake. Right?!
>> > Cheers
>> > Matteo
>> > 2015-06-06 11:33 GMT+02:00 Sebastiaan Couwenberg
>> > <sebastic at xs4all.nl <mailto:sebastic at xs4all.nl>>:
>> > On 06/06/2015 11:30 AM, Matteo Ghetta wrote:
>> >> So what exacly should I do? Should I re-run ccmake in order to
>> >> have another list of all the paths?
>> > Throw away your old build directory, recreate it and run `cmake
>> > ..` from inside it.
>> > Kind Regards,
>> > Bas
>> > _______________________________________________ Qgis-developer
>> > mailing list Qgis-developer at lists.osgeo.org
>> > <mailto:Qgis-developer at lists.osgeo.org>
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v2
>> iEYEARECAAYFAlVywGQACgkQDAH1YiCxBgmFEQCfe9yilTx1/OrAk74T/gRI6mj3
>> 8KIAn3c0qFmf3o6OW9mA/kGjMBwaVf5F
>> =WPOX
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150607/8178a3cb/attachment.html>
