[Qgis-developer] Bug in symbol size data-defined override
Alexandre Neto
senhor.neto at gmail.com
Mon Jun 8 02:10:06 PDT 2015
Hi Vincent,
On Mon, Jun 8, 2015 at 9:03 AM, Vincent Mora <vincent.mora at oslandia.com>
wrote:
> Is the size-scale method set to Diameter ? If it's not the case (i.e.
> scale method area), then a square root is applied if the size is defined by
> an expression.
You are right, setting size-scale to diameter, makes it work.
Not sure if data-defined override for Symbol Size should even be connected
to the size-scale method, since in this case it should simply override the
symbol size value.
Setting a value directly on the Symbols Size input box won't take in
consideration the size-scale method (it always use diameter).
Don't know if this is now more consistent in 2.9.
Thanks for looking at this,
Alexandre
> Cheers,
> V.
> Thanks,
> Alexandre Neto
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150608/dcea3b91/attachment.html>
