[Qgis-developer] Bug in symbol size data-defined override
Anita Graser anitagraser at gmx.at
Mon Jun 8 01:30:19 PDT 2015
On Jun 8, 2015 10:03 AM, "Vincent Mora" <vincent.mora at oslandia.com> wrote:
> On 05/06/2015 16:46, Alexandre Neto wrote:
>> I'm still at 2.8.1 (I have no administrator permissions on this machine)
>> Using data-defined override on a marker symbol does not seem to be
working
>> as it should. Comparing a layer where the marker size is set to 50 and
>> another where we use 50 as an expression in data-defined override, they
do
>> not look the same, and I guess they should.
>> Can anyone can confirm this, whether in 2.8 or in master?
> Is the size-scale method set to Diameter ? If it's not the case (i.e.
scale method area), then a square root is applied if the size is defined by
an expression.
It's left on default. So probably area. It's not clear for the user that
there is a connection between this seeing and data defined size.
Best wishes
Anita
> Cheers,
> V.
>> Thanks,
>> Alexandre Neto
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150608/359b053f/attachment.html>
