[Qgis-developer] Embedded layers
Andreas Neumann a.neumann at carto.net
Mon Jun 15 12:36:18 PDT 2015
Yes - it should behave like your describe.
However, the change only happens if you reload the project that links
the groups/layer from the other project. Are you expecting it to live
update if you change the master project?
Andreas
On 15.06.2015 20:44, Paolo Cavallini wrote:
> Hi all,
> AFAIK, embedding layers and groups in a project should provide a live
> link to original project, so if styling of a layer changes in the
> source, changes should be reflected in the project that embeds them.
> I just checked, and this does not seem to happen on QGIS 2.8.2: am I
> missing something, or this is a bug?
> Thanks.
