[Qgis-developer] Qgis 91e44ea crash browsing GRASS 7 vector
Radim Blazek
radim.blazek at gmail.com
Fri Jun 19 02:29:24 PDT 2015
On Mon, Jun 15, 2015 at 10:03 AM, Roy <royroge at outlook.com> wrote:
> Thank you for the info Radim!
The problem is not easy, I have create new issue
https://hub.qgis.org/issues/13002
ideas how to solve it are welcome.
Radim
> Il 15/06/2015 08.25, Radim Blazek ha scritto:
>> Hi Roy,
>> this is known issue I haven't been able to fix so far. It has
>> something to do with getting list of vector layers in thread. It seems
>> to only happen with GRASS 7 on windows when Vect_cidx_get_* functions
>> are used in thread (browser items are populated in threads). I have
>> already double checked the code including relevant parts of GRASS
>> vector lib without success.
>> Radim
>> On Thu, Jun 11, 2015 at 10:37 AM, Roy <royroge at outlook.com> wrote:
>>> Hi,
>>> i'm testing "QGIS desktop 2.9.0 with grass 7" and it crashes when
>>> browsing
>>> a grass 7 DB; (windows osgeo4w 32 bit)
>>> i simply prepared a grass7 location and mapset, imported a vector
>>> stopped grass and opened QGIS, with browser panel QGIS crashes
>>> navigating to the imported vector,
>>> if you confirm i can open a bug report, Roy
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
