[Qgis-developer] Qgis 91e44ea crash browsing GRASS 7 vector
Radim Blazek radim.blazek at gmail.com
Mon Jun 22 01:23:54 PDT 2015
Hi Roy,
the bug is fixed in OSGeo4w qgis-dev-2.9.0-104. Apart from browsing
and displaying GRASS data you should be able to import data to GRASS
in the browser with drag and drop. There are still some issues with
import which I am trying to sort out:
- vector import with more features is slow due to slow inserting to db
(provider problem, v.in.ogr is fast)
- temporary vector maps (polygons cleaning) are not deleted
- animated import icon is missing, it means no layer icon = import
running, for now on Windows
Testing is welcome.
Radim
On Mon, Jun 15, 2015 at 10:03 AM, Roy <royroge at outlook.com> wrote:
> Thank you for the info Radim!
> Il 15/06/2015 08.25, Radim Blazek ha scritto:
>> Hi Roy,
>> this is known issue I haven't been able to fix so far. It has
>> something to do with getting list of vector layers in thread. It seems
>> to only happen with GRASS 7 on windows when Vect_cidx_get_* functions
>> are used in thread (browser items are populated in threads). I have
>> already double checked the code including relevant parts of GRASS
>> vector lib without success.
>> Radim
>> On Thu, Jun 11, 2015 at 10:37 AM, Roy <royroge at outlook.com> wrote:
>>> Hi,
>>> i'm testing "QGIS desktop 2.9.0 with grass 7" and it crashes when
>>> browsing
>>> a grass 7 DB; (windows osgeo4w 32 bit)
>>> i simply prepared a grass7 location and mapset, imported a vector
>>> stopped grass and opened QGIS, with browser panel QGIS crashes
>>> navigating to the imported vector,
>>> if you confirm i can open a bug report, Roy
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
