[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Nathan Woodrow
madmanwoo at gmail.com
Fri Jun 19 04:08:37 PDT 2015
I would say they are getting skipped in the rule check so fall into the
else rule.
On Fri, 19 Jun 2015 9:05 pm Alexandre Neto <senhor.neto at gmail.com> wrote:
> Using the rule-based symbology with several rules and an ELSE expression.
> If you, in map canvas legend, set a rule "layer" to invisible, all it's
> features will be represented with the ELSE Symbol.
> Not sure if this is the expected behaviour. I would expect that those
> feature would simply became invisible.
> Should I open a ticket?
> Thanks,
> Alexandre Neto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/5f9f86cc/attachment.html>
