[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Alexandre Neto senhor.neto at gmail.com
Fri Jun 19 04:18:51 PDT 2015
Indeed Nathan,
But do you thinks that is what you were expecting? when you turn the
"layer" off?
Alexandre
On Fri, Jun 19, 2015 at 12:08 PM, Nathan Woodrow <madmanwoo at gmail.com>
wrote:
> I would say they are getting skipped in the rule check so fall into the
> else rule.
> On Fri, 19 Jun 2015 9:05 pm Alexandre Neto <senhor.neto at gmail.com> wrote:
>> Using the rule-based symbology with several rules and an ELSE expression.
>> If you, in map canvas legend, set a rule "layer" to invisible, all it's
>> features will be represented with the ELSE Symbol.
>> Not sure if this is the expected behaviour. I would expect that those
>> feature would simply became invisible.
>> Should I open a ticket?
>> Thanks,
>> Alexandre Neto
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/9ee6ceaf/attachment.html>
