[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Etienne Trimaille etienne.trimaille at gmail.com
Fri Jun 19 04:36:05 PDT 2015
I've this kind of bug too.
If you create a categorized symbology, apply the change and then switch to
a ruled-based symbology (keeping the previous rules), you will see that the
ELSE statement will draw features twice.
Enable "show feature count" to check.
I didn't check if there is a ticket for that.
2015-06-19 13:18 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
> Indeed Nathan,
> But do you thinks that is what you were expecting? when you turn the
> "layer" off?
> Alexandre
> On Fri, Jun 19, 2015 at 12:08 PM, Nathan Woodrow <madmanwoo at gmail.com>
> wrote:
>> I would say they are getting skipped in the rule check so fall into the
>> else rule.
>> On Fri, 19 Jun 2015 9:05 pm Alexandre Neto <senhor.neto at gmail.com> wrote:
>>> Using the rule-based symbology with several rules and an ELSE
>>> expression. If you, in map canvas legend, set a rule "layer" to invisible,
>>> all it's features will be represented with the ELSE Symbol.
>>> Not sure if this is the expected behaviour. I would expect that those
>>> feature would simply became invisible.
>>> Should I open a ticket?
>>> Thanks,
>>> Alexandre Neto
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/b0e93ff6/attachment-0001.html>
