[Qgis-developer] Join by location does not work when layer have equivalent filed names
Alexandre Neto senhor.neto at gmail.com
Fri Jun 19 04:14:15 PDT 2015
Can someone confirm that the join by location functionality does not fill
the fields with values from the joined layer. This happens if the Target
vector layer has equal or similar (with caps) field names.
The new fileds are renamed to fieldname_1 but the values are no set.
Can/should I open a ticket?
Thanks,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/dccbf917/attachment.html>
