[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Alexandre Neto senhor.neto at gmail.com
Fri Jun 19 07:13:47 PDT 2015
So, can I open a ticket?
Alexandre
On Fri, Jun 19, 2015 at 12:50 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
>  In my opinion this is a bug. I agree that by switching off the rule
> should not make the features fall into the ELSE rule. At least from a
> usability point of view. Or we need to ELSE rules - a "TRUE ELSE" rule that
> behaves like now and an "ELSE" rule that behaves like the users expect it
> to behave.
> Andreas
> On 19.06.2015 13:36, Etienne Trimaille wrote:
>  I've this kind of bug too.
> If you create a categorized symbology, apply the change and then switch to
> a ruled-based symbology (keeping the previous rules), you will see that the
> ELSE statement will draw features twice.
> Enable "show feature count" to check.
>  I didn't check if there is a ticket for that.
> 2015-06-19 13:18 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
>>  Indeed Nathan,
>>  But do you thinks that is what you were expecting? when you turn the
>> "layer" off?
>>  Alexandre
>> On Fri, Jun 19, 2015 at 12:08 PM, Nathan Woodrow <madmanwoo at gmail.com>
>> wrote:
>>> I would say they are getting skipped in the rule check so fall into the
>>> else rule.
>>>   On Fri, 19 Jun 2015 9:05 pm Alexandre Neto <senhor.neto at gmail.com>
>>> wrote:
>>>>   Using the rule-based symbology with several rules and an ELSE
>>>> expression. If you, in map canvas legend, set a rule "layer" to invisible,
>>>> all it's features will be represented with the ELSE Symbol.
>>>> Not sure if this is the expected behaviour. I would expect that those
>>>> feature would simply became invisible.
>>>> Should I open a ticket?
>>>>  Thanks,
>>>>  Alexandre Neto
>>>>   _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/7e12b310/attachment-0001.html>
