[Qgis-developer] Use the style tab widget in a Python plugin
kimaidou
kimaidou at gmail.com
Tue Jun 23 07:38:26 PDT 2015
Hum...
After digging a little deeper, I found something interesting in the Python
Cookbook [1]
It seems I need to use the class QgsRendererV2Widget
[1]
http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/vector.html#creating-custom-renderers
2015-06-23 16:29 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> The LayerBoard plugin I made during the HF in "Nooooooooodebo" shows a
> table of all vector (and raster) layers and allows to edit some properties
> directly by editing the table cells, such as max and min scale, layer name,
> title and abstract, assign SRS, etc.
> I would like to display the content of the Style tab of the layer
> properties dialog in a panel right to the table. This tab will show the
> style interface refreshed whenever the user clicks on a layer in the tab,
> and let her/him change the style for this layer the same way we do via the
> layer properties dialog.
> I have searched a bit in the api and in the source code, but cannot find
> the right way to do so. I have not found a custom Widget which I can
> instantiate with the layer and wich will provide me all the logic
> underneath.
> Is this even possible ? Has anyone an idea of how to to this without
> rewriting all the code ( connection between ui elements and slots)
> Thanks in advance
> Michaël
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150623/00abc3c7/attachment.html>
