[Qgis-developer] login to postgres/postgis from QGIS
Olivier Dalang
olivier.dalang at gmail.com
Mon Mar 2 23:10:22 PST 2015
Is your database spatially enabled ? Try to run 'create extension postgis;"
in pgadmin.
Bests,
Olivier
On Feb 27, 2015 8:08 AM, "Otto Dassau" <dassau at gbd-consult.de> wrote:
> Hi,
> I cannot login to a postgis database with QGIS as a normal user 'testuser'.
> But I can login with psql and using pgadmin3.
> CREATE ROLE testuser LOGIN
> NOSUPERUSER INHERIT NOCREATEDB NOCREATEROLE NOREPLICATION;
> I get following error in QGIS:
> CET ERROR: function postgis_version() does not exist at character 8
> CET HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> CET STATEMENT: SELECT postgis_version()
> If I create another user as SUPERUSER I can login without problems. What
> could be the reason for this?
> Thanks a lot
> Otto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150303/b8121c12/attachment.html>
