[Qgis-developer] login to postgres/postgis from QGIS
Alessandro Pasotti
apasotti at gmail.com
Mon Mar 2 23:28:40 PST 2015
2015-03-03 8:10 GMT+01:00 Olivier Dalang <olivier.dalang at gmail.com>:
> Is your database spatially enabled ? Try to run 'create extension postgis;"
> in pgadmin.
> Bests,
I've got the same error once, and the reason was that the DB wasn't
spatially enabled, that said I believe that a better message should
point the user to the right direction.
Otto: can you please file a ticket for this issue?
Alessandro Pasotti
w3: www.itopen.it
