[Qgis-developer] Integer fields converted to text when exported from SQLite
Roy royroge at outlook.com
Thu Mar 5 04:14:31 PST 2015
I can confirm this also for QGIS 2.8.1 both in windows and ubuntu,
Roy.
Il 05/03/2015 09.15, Christophe Damour ha scritto:
> Hi,
> When I save a SpatiaLite layer as a shp or tab layer, every integer
> field gets converted to a text field.
> Same problem if I export the layer to shp from DB Manager.
> Did someone ever experienced this problem ?
> I work on Windows 7 64 bits, with QGis 2.6.1 64 bits.
> Thanks for any hint,
