[Qgis-developer] Integer fields converted to text when exported from SQLite
Roy royroge at outlook.com
Fri Mar 6 01:10:06 PST 2015
I filled a bug report for this
Il 05/03/2015 09.15, Christophe Damour ha scritto:
> Hi,
> When I save a SpatiaLite layer as a shp or tab layer, every integer
> field gets converted to a text field.
> Same problem if I export the layer to shp from DB Manager.
> Did someone ever experienced this problem ?
> I work on Windows 7 64 bits, with QGis 2.6.1 64 bits.
> Thanks for any hint,
