[Qgis-developer] Integer fields converted to text when exported from SQLite
Roy
royroge at outlook.com
Sun Mar 8 00:57:41 PST 2015
You can use Spatialite_gui,
Roy.
P.S. you wrote directly to me not to the mailing list...
Thank you Roy for the bug report. Hope it will be corrected soon...
In the mean time, I am trying to find a workaround using ogr2ogr.
I had a look at the doc but didn't find a way to force column format
conversion.
Can anybody ont me in the right direction ?
Thanks,
Christophe
Le 06/03/2015 10:10, Roy a écrit :
I filled a bug report for this
Il 05/03/2015 09.15, Christophe Damour ha scritto:
> Hi,
> When I save a SpatiaLite layer as a shp or tab layer, every integer
> field gets converted to a text field.
> Same problem if I export the layer to shp from DB Manager.
> Did someone ever experienced this problem ?
> I work on Windows 7 64 bits, with QGis 2.6.1 64 bits.
> Thanks for any hint,
>> Hi,
> Qgis-developer mailing list
