[Qgis-developer] problem with 'toreal' in field calculator
Junior Delaz
delazj at gmail.com
Tue Mar 10 10:25:32 PDT 2015
hi,
If your field is recognized by QGIS as a string one, trying to overwrite
its values type will fail as they are intended to be string in THIS field.
This is why when you create a new numeric field and make conversion, it's
ok (this new field expect numeric values, so it'll recognize your
conversion).
2015-03-10 18:08 GMT+01:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
> Hi all,
> I have a filed made up by numeric values but recognized as text (should be
> a WFS issue and not a QGIS problem).
> I've used the 'toreal' function of the field calculator in order to update
> the field but nothing changed (numbers are still read as text).
> Strange is that if I create a new field using the 'toreal' function,
> values are correctly read as numbers and not as text.
> Am I missing something or can be a bug?
> BTW: debian testing and QGIS 2.8.1
> Cheers
> Matteo
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150310/ea19388a/attachment-0001.html>
