[Qgis-developer] problem with 'toreal' in field calculator
    Matteo Ghetta
    matteo.ghetta at gmail.com
    Tue Mar 10 10:29:23 PDT 2015
Hi Junior,
thanks, get it. So numeric conversion are sinful only between numeric
fields right?
Cheers
Matteo
2015-03-10 18:25 GMT+01:00 Junior Delaz <delazj at gmail.com>:
> hi,
> If your field is recognized by QGIS as a string one, trying to overwrite
> its values type will fail as they are intended to be string in THIS field.
> This is why when you create a new numeric field and make conversion, it's
> ok (this new field expect numeric values, so it'll recognize your
> conversion).
> 2015-03-10 18:08 GMT+01:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
>> Hi all,
>> I have a filed made up by numeric values but recognized as text (should
>> be a WFS issue and not a QGIS problem).
>> I've used the 'toreal' function of the field calculator in order to
>> update the field but nothing changed (numbers are still read as text).
>> Strange is that if I create a new field using the 'toreal' function,
>> values are correctly read as numbers and not as text.
>> Am I missing something or can be a bug?
>> BTW: debian testing and QGIS 2.8.1
>> Cheers
>> Matteo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150310/aac51614/attachment.html>
