[Qgis-developer] Is it possible to: Print canvas without Composer and draw polygon in Composer?
Alexandre Neto
senhor.neto at gmail.com
Fri Mar 13 02:49:23 PDT 2015
On Fri, Mar 13, 2015 at 9:40 AM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> > · In the PrintComposer you can draw square, ellipse, ect - but
> > can I draw a polygon?
> Use my favourite plugin from Boris:
> http://plugins.qgis.org/plugins/NewMemoryLayer/
> activating this one, gives you a 'create new memory layer' in your Layer
> menu, where you can then choose point/line/polygon and it will appear as
> a layer into your map, and edit with the normal tools.
> You can style it as every other layer.
(Also one of my favorite plugins)
Just to remind that that since 2.8, this feature is now core and was called
"add new scratch layer", and it's available in the Create
Shapefile/Spatialite Button.
There is another plugin to save the memory layer into the project file.
This one is not a core feature, but works fine with scratch Layers
Cheers,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150313/92771016/attachment.html>
