[Qgis-developer] Is it possible to: Print canvas without Composer and draw polygon in Composer?
Lene Fischer
lfi at ign.ku.dk
Fri Mar 13 03:05:50 PDT 2015
Hi Richard and Alexandre,
Thanks –
The scratch layer is wonderful – but deleted when I close the project (that’s –OK) so I can´t save drawings in the printcomposer.
And Save as Image – forgot that – I like the Clipping tool from windows – and woul prefer a ‘Copy to Clipboard’
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[cid:image001.gif at 01D03029.2F3EC6A0]
Fra: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne af Alexandre Neto
Sendt: 13. marts 2015 10:49
Til: Richard Duivenvoorde
Cc: qgis-dev
Emne: Re: [Qgis-developer] Is it possible to: Print canvas without Composer and draw polygon in Composer?
On Fri, Mar 13, 2015 at 9:40 AM, Richard Duivenvoorde <rdmailings at duif.net<mailto:rdmailings at duif.net>> wrote:
> · In the PrintComposer you can draw square, ellipse, ect - but
> can I draw a polygon?
Use my favourite plugin from Boris:
http://plugins.qgis.org/plugins/NewMemoryLayer/
activating this one, gives you a 'create new memory layer' in your Layer
menu, where you can then choose point/line/polygon and it will appear as
a layer into your map, and edit with the normal tools.
You can style it as every other layer.
(Also one of my favorite plugins)
Just to remind that that since 2.8, this feature is now core and was called "add new scratch layer", and it's available in the Create Shapefile/Spatialite Button.
There is another plugin to save the memory layer into the project file.
This one is not a core feature, but works fine with scratch Layers
Cheers,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150313/99b5b661/attachment-0001.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150313/99b5b661/attachment-0001.gif>
