[Qgis-developer] Project Idea For GSoc
Nancy
nancy.kapri at research.iiit.ac.in
Sat Mar 14 11:20:02 PDT 2015
Hi all,
My name is Nancy. I am a dual degree Computer Science student at IIIT-H and pursuing Masters in the field of Spatial Informatics.
I have been an avid user of QGIS for the past year as my interests lies in it.I would like to introduce to you this project idea for GSoC 2015, in which I am interested.
The idea of the project is Pan Sharpening in QGIS.The main idea of pan sharpening is to combine registered high spatial resolution panchromatic (pan) and lower spatial resolution multispectral imagery to synthesize higher resolution multispectral imagery.The degree of misregistration between bands and the correlation of intensity values are key factors in generating radiometrically accurate and visually crisp output images.
There are many algorithm for Pan Sharpening :-
1>Projective
2>Multiplicative
3>High Pass Filter
4>Hue, Saturation, Intensity
But I would like to work on Projective method as it provides better results in terms of preserving the color of the multispectral image. The other algorithms all cause a color shift of one type or another from the original multispectral image.
There are two components to the projective pan sharpening algorithm. The first component determines the linear radiometric relationship between the pan and multispectral bands and the second processes pixels to produce the sharpened product.
Benefit of this project will be that by increasing the spatial resolution of the high spectral resolution multispectral image,many other image processing tasks which are performed on the multispectral image are enhanced.We will be able get clear boundaries for clear extraction of features from the image and better vectorisation.
We have this functionality in GRASS and other softwares so we are trying to implement it in QGIS.
Regards
Nancy
IIIT-Hyderabad.
