[Qgis-developer] wrapping changeAttributeValue between begin and end EditCommand
Luigi Pirelli
luipir at gmail.com
Mon Mar 16 13:32:28 PDT 2015
I used a different approach attaching to end Editing action to do a
similar work.
The logic is, start editing, do modification, stop editing is
intercepted to save EditingBuffer and then roolback all modification.
Then process editing buffer to create values basing on a rule and them
I can add/change the modified records with a new editing session
without user interaction.
I don't know if this can ba applied to your use case.
regards, Luigi Pirelli
https://www.linkedin.com/in/luigipirelli
https://github.com/luipir
https://www.elance.com/s/edit/luigipirelli/
On 15 March 2015 at 15:04, francescoboccacci at libero.it
<francescoboccacci at libero.it> wrote:
> Hi all,
> i have a problem with beginEditCommand and endEditCommand wrapping.
> In my plugin i capture the layer.featureAdded signal :
> self.layer.featureAdded.connect(self.myfunction)
> The scope of my function is to change attribute of the feature added
> according with some rules.
> I wrap self.layer.changeAttributevalue between
> self.layer.beginEditCommand('My custom value') and
> self.layer.endEditCommand() but when i added a feature i can't see in
> Undo/redo window the label My custom value but my value is changed.
> This cause a Qgis 2.8.2 crash when i try to rollback my changes.
> P.S If i comment my change values function and i write the code in a python
> console i can see my beginEditCommand label and no crash happend.
> Anyone can help me?
> Thanks
> Francesco
> Qgis-developer mailing list
