[Qgis-developer] wrapping changeAttributeValue between begin and end EditCommand
Matthias Kuhn matthias at opengis.ch
Mon Mar 16 13:47:36 PDT 2015
On 03/16/2015 09:32 PM, Luigi Pirelli wrote:
> I used a different approach attaching to end Editing action to do a
> similar work.
> The logic is, start editing, do modification, stop editing is
> intercepted to save EditingBuffer and then roolback all modification.
> Then process editing buffer to create values basing on a rule and them
> I can add/change the modified records with a new editing session
> without user interaction.
It would be so nice to be able to be able to register a trigger that is
executed to do this kind of things and data validation directly before
it enters the edit buffer.
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150316/56c24930/attachment.pgp>
