[Qgis-developer] Move feature causes QGIS to crash
Mark Wynter mark at dimensionaledge.com
Fri Mar 20 18:15:56 PDT 2015
I’m running QGIS2.8.1 on Centos6.5
If I add a points table from PostGIS, hit edit, and attempt to move the location of a point feature:
Method 1 - use the ‘node' tool to drag a point to a new location.  This works.
Method 2 - use the ‘move feature’ tool - as soon as I click on the point to be moved, QGIS crashes.
This is message returned on the CLI.
qgis: GeometryComponentFilter.cpp:34: virtual void geos::geom::GeometryComponentFilter::filter_ro(const geos::geom::Geometry*): Assertion `0' failed.
Aborted
This is my QGIS setup
QGIS version	2.8.1-Wien	QGIS code revision	exported
Compiled against Qt	4.8.5	Running against Qt	4.8.5
Compiled against GDAL/OGR	1.11.1	Running against GDAL/OGR	1.11.1
Compiled against GEOS	3.4.2-CAPI-1.8.2	Running against GEOS	3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version	9.3.5	SpatiaLite Version	2.4.0
QWT Version	6.0.1	PROJ.4 Version	480
QScintilla2 Version	2.8.4
Has anyone else encountered this… >
Not sure how reproduceable its going to be….?
Mark
