[Qgis-developer] wrong attribute values for postgis data in Feature attribute form
Raymond Nijssen
r.nijssen at terglobo.nl
Thu Mar 26 04:20:32 PDT 2015
Thanks all for pointing things out!
My view did have a unique id, it is just a sub set of another table. So
by selecting it everything is solved.
On 26-03-15 11:45, Matthias Kuhn wrote:
> Hi Raymond,
> The feature shown in the identify result is the one queried with the
> geographic location.
> For some reason the feature shown in the feature form is not a copy of
> the identified data (feature) but queried again with its feature id.
> For the views on pg databases I have here, the primary key of the main
> source table is shown (which is the first field of the query that
> defines the view), so it is fine by default. Not sure about the
> heuristics used to get the default PK field.
> Matthias
> On 03/26/2015 10:57 AM, Raymond Nijssen wrote:
>> Thanks Regis, that was exactly the issue. The (boolean!) field
>> 'inonderzoek' was used as a key. When I change that to 'gid' in the
>> Add PostGIS Table dialog, everything works correctly.
>> Can anyone tell me why QGIS picks that boolean field for most of my
>> tables? Can I change that behaviour by changing my database structure?
>> http://terglobo.nl/downloads/qgis_add_postgis_table_wrong_key.png
>> And how can the identify results be correct anyway?
>> Tnx,
>> Raymond
>> dbname='bag' host=localhost port=5432 user='postgres' sslmode=disable
>> key='inonderzoek' estimatedmetadata=true srid=28992 type=POLYGON
>> table="bagactueel"."pandactueelbestaand" (geovlak) sql=
>> On 26-03-15 10:34, Régis Haubourg wrote:
>>> Hi, I have seen such troubles when the choosen primary key from qgis
>>> side is
>>> not unique .
>>> Symptoms: selecting one feature select severals unrelated features of
>>> the
>>> same layer. relation with attributes is broken also.
>>> Can you check in your layer's definition (general tab of layer
>>> properties)
>>> if you choose gid field as key, and check if it is really unique in
>>> postgis?
>>> Cheers
>>> Régis
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/wrong-attribute-values-for-postgis-data-in-Feature-attribute-form-tp5195518p5195523.html
>>> Sent from the Quantum GIS - Developer mailing list archive at
>>> Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
